Old 08-12-2016, 04:51 AM   #3
Woodfin
Liked 274 Times in 105 Posts
Default Re: ?? regarding 1992 corvette
Suggestions, look closely at the secondary wire between coil and distributor. Look at coil terminal for corrosion or carbon tracking.
Swap the ecu relay with the relay from another component that uses the same relay.
Another possibility is the primary connector at the ignition coil. It is a known issue for the primary connector to break internally. A replacement "pigtail" is available.
