Old 12-18-2007, 10:23 PM   #1
Steve Reynolds
Default Re: Throttle stop racing first timer needs a little help
Bayou,
First let me ask you if you plan on bracket racing alot of faster cars?
I know this sounds silly, but I have my reasons.
I race divisional S/ST on an occationall basis, but bracket race alot, and used the throttle stop all season.
I had alot of success bracket racing with the stop, against the faster cars(dragsters).
Set the timers, dont change it all day, and follow the weather for dial in.
The extra data you gain from using the stop all season will help when it comes division time.
Hopes this was a little help. My opinion is only worth a six pack most days.
Steve Reynolds is offline   Reply With Quote
Old 12-19-2007, 07:32 AM   #2
Bob Verwold
Bob Verwold's Avatar
What Steve said is true also your 10.90 dial-in with the mph you run really messes with their heads. I run s/st and always use the stop the more info you have the better off you are. Good luck.
Bob Verwold is offline   Reply With Quote
Old 12-19-2007, 02:28 PM   #3
Bayou Shoe
Thanks guys and yes with running allot of 1/8 mile races I see large amounts of dragsters, so I think running the stops would help me out. I am new to all this and if any of you would like to help me a little further in getting this thing set up please drop me an e mail at Herbertsracingteam@gmail.com once again thanks it is appreciated.
Bayou Shoe is offline   Reply With Quote
Old 12-19-2007, 09:22 PM   #4
luckydog
luckydog's Avatar
Really???
Damien Hazelton
Lucky Dog Racing
luckydog is offline   Reply With Quote
Old 12-19-2007, 10:55 PM   #5
Steve Reynolds
I think what Bob is referring to is that if running 1/4 mile flat out and lets say your car runs 9.90's or even low 10's without the stop, you set up for 10.90 on the stop. This will slow your cars dial in, but only affect the MPH slightly depending on when and where you use the stop, and how long your on it.
Example, my sm block Nova will run 9.80 @ 135 mph w/o the stop. 10.90 @ 131 mph on the stop.
You can see that if you are racing a 8.0's Dragster, he will not reach you until way past the MPH cones on the track, because of the et difference. The extra mph you have can mess them up on judging the stripe.
Worked for me, anyway.
