Old 07-12-2016, 03:58 PM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Tube bars out to front frame on a mopar?
Hi,
This is a quote from the 2016 NHRA Rules Book regarding roll bars in Stock.....
ROLL BARS
Mandatory in AA/S through M/S, AA/SA through M/SA, FS/A
through FS/L, in all convertibles and in any car running 11.49 or
quicker, permitted in slower cars. Front braces may not extend in
front of firewall. Six-point attachments permitted. Roll cage
mandatory in any car running 9.99 or quicker, permitted in slower
vehicles. See General Regulations 4:10, 4:11, 6:3.
It might get through tech but if called on it I think that the Rule Book would prevail....
Just my thoughts because I wouldn't want to give bad info that might get the guy tossed..
bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-12-2016, 04:54 PM   #2
Coleydog
Liked 53 Times in 38 Posts
I guess we need to know what they mean by "front braces". Is the "roll cage" just permitted in the driver compartment on 9.99 and quicker with no bars going to the front rails? Very hard to interpret how it's worded. The cars are faster now and the rules are still in the 60's it seems. Without some form of "bracing" some of these unibody cars are dangerously coming close to breaking apart within a year.
Old 07-12-2016, 08:21 PM   #3
Bob Mulry
Bob Mulry's Avatar
Hi,
The rule had always been..........
Nothing through the firewall......
I don't think that it would change because a cage was the car.....
A K/SA can run a cage if desired......
Just making Stock into Super Stock and Super Stock into Comp....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-12-2016, 09:51 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Guys that was amended 10/26/15 to section 10A, section 7 page 23 It is legal to run the bars thru the firewall on the inside or over the top of the inner fender .
However section 4 above it says its not , it has been legal since the start of this season. ....You know NHRA never makes mistakes in the rule book !
I double checked this with Dave Ley before I did any.
Old 07-12-2016, 11:22 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Tom, I looked at the published amendments from mid-2015 and all the publications since then and do not find what you are talking about. In fact, the 10/26/15 amendments are still on the NHRARacer.com site and I do not see that in the document there either.
Old 07-12-2016, 11:36 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Here it is
SECTION 10A: STOCK CARS, BODY:7, FIREWALL (Page 10) (10/26/2015) Alterations prohibited unless expressly permitted in this section. Firewall coverings prohibited. Where heater/air conditioning units have been removed, area must be covered with minimum .024- inch steel or .032-inch aluminum, including rear hood seal/flange, as on GM A-body. Minor firewall modifications permitted to C5 and C6 Corvettes for transmission installation. Roll cage tubing may run across top or side of inner fender well/strut tower and attach to frame horn. See General Regulations 7:4.
Old 07-13-2016, 08:17 AM   #7
Dwight Southerland
Ahhh! I was stopping at the Roll Bar Section; did not read the Firewall Section. I stand corrected.
Old 07-14-2016, 07:45 PM   #8
SSGT Mustang
Liked 204 Times in 54 Posts
"FIREWALL
"Alterations prohibited unless expressly permitted in this section. Firewall coverings prohibited.Where heater/air conditioning units have been removed, area must be covered with minimum .024-inch steel or .032- inch aluminum, including rear hood seal/flange, as on GM A-body. Minor firewall modifications permitted to C5 and C6 Corvettes for transmission installation. Roll cage tubing may run across top or side of inner fender well/strut tower and attach to frame horn. "
The last sentence has never been made clear (at least not to my knowledge). Does it apply to the corvettes or all stocker?
SSGT Mustang is offline   Reply With Quote
Old 07-14-2016, 07:46 PM   #9
Tom Goldman
It applies to all Stockers.
Old 07-14-2016, 07:48 PM   #10
SSGT Mustang
Thanks
