Which u-joint is the best/strongest of the 1350 kind.
Thanks. |
Liked 264 Times in 103 Posts
the market will have a number of acceptable options.
Strange #U1641 is a good choice. In addition, other driveshaft builders will have an equivalent part. If you have a driveshaft shop near they will have or can get a HD 1350 series. You want a solid cross [no grease fitting nor grease channel] |
Liked 138 Times in 51 Posts
I've had excellent service from Spicer solid u-joints.
LOCOMOTION Racing |
Thank you.
Liked 320 Times in 102 Posts
Almost any without the trunnion cross drilled for grease.....
The smaller (and more) needles the better.... You get a larger diameter trunnion and better load capacity with more needle bearings.... Bob
