Old 06-08-2016, 12:23 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: no oil at roller rockers
Originally Posted by carl hinkson View Post
Make sure the galley plugs are installed in back of the timing gear.
that and the by pass
Old 06-08-2016, 10:46 PM   #2
carl hinkson
Liked 18 Times in 10 Posts
What bypass?
carl hinkson is offline   Reply With Quote
Old 06-08-2016, 11:29 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
By-pass on the oil filter adapter?
You also might want to check and see if the previous owner might have installed oil restricters in the lifter feed oil galleys at the back of the motor.
Hope you find your problem!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-09-2016, 12:55 AM   #4
Allen Sherman
Banned
Liked 5 Times in 3 Posts
If the pushrod oil feed hole in the lifter isn't in the band of the lifter or doesn't have a groove machined from the band to the oil feed hole this could be your issue, sometimes the lifter bore clearance isn't enough if the feed hole isn't in the band. Just some more places to look...
Allen Sherman is offline   Reply With Quote
Old 06-09-2016, 07:55 AM   #5
nhramnl
Liked 358 Times in 83 Posts
It's not a Bowtie block, is it? Because with those, engine builders have been known to forget to reinstall the galley plug that feeds the cam tunnel, which causes seemingly unexplained, but repeated (until you figure it out) cam bearing and lifter failures, due to lack of oil. Obviously, if the camshaft isn't getting any oil, the pushrods and rocker arms won't, either.
Old 06-09-2016, 10:56 AM   #6
henrys57wagon
henrys57wagon's Avatar
Thanks all, he has not pulled the engine yet, will update when more is found.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 06-09-2016, 02:02 PM   #7
carl hinkson
What galley plug are talking about that feeds the cam tunnel ???
Old 06-09-2016, 03:19 PM   #8
nhramnl
It's actually a small cup plug (on early Bowties I think it was .500 in diameter, on later blocks, .470. It is pressed in, and is under the rear main. I had an almost season-long problem failing cam bearings and lifters because the engine machinist removed the plug (to bottle-brush the oil galleys) and forgot to reinstall it. There was very little oil going up-top, and invariably, at least one of the cam bearings would turn. Finally got to the point where I said "No more bearings and camshafts and lifters, because it can't possibly be bad or improperly installed parts...again". We did a deep-dive for weird, uncommon problems and somebody who had experienced the same thing straight-out said "Your engine guy removed the plug and forgot to reinstall it".
