Liked 13 Times in 6 Posts
I am able to move crank 3 degrees back and forth with no top gear or valve train movment. Put an old used belt on and there is very little movment-maybe 1/2 degree, the same as an old comp. cam unit the jesel unit replaced.
jesel says 3 degrees is normal and i could send the belt to them to measure. I bought a new belt and it is the same ( 3 degrees) as the original with 72 runs. The questions are why would there be a difference and would it effect valve timing and or performance. jim johnston ss/oa |
Liked 99 Times in 49 Posts
I find the same thing on mine, the comp belt drive is a little less.
Possible line honing, shortening the dim. between gears?.
Liked 295 Times in 102 Posts
Yep. I use one.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-17-2016 at 08:06 PM. |
Thanks for the replies - it appears it is a hit or miss deal to get a belt that is tight. The fact is that a 5 year old used of the shelf jesel belt and a much used comp. cam belt unit seem tight,new jesel belts not,all on the same engine.
The question still remains what would this do to cam timing and or performance. jim johnston ss/oa |
Liked 331 Times in 179 Posts
Problem might be that the teeth on the belt DO NOT match the tooth spacing on the pulley--- take a close look at the interaction between the teeth on the belt and your pulley happened to us before might have to try several gilmer belts til you get one that fits "just right". Fed 387
