Possible line honing, shortening the dim. between gears?.
Liked 306 Times in 103 Posts
Yep. I use one.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-17-2016 at 08:06 PM. |
Liked 13 Times in 6 Posts
Thanks for the replies - it appears it is a hit or miss deal to get a belt that is tight. The fact is that a 5 year old used of the shelf jesel belt and a much used comp. cam belt unit seem tight,new jesel belts not,all on the same engine.
The question still remains what would this do to cam timing and or performance. jim johnston ss/oa |
Liked 332 Times in 180 Posts
Problem might be that the teeth on the belt DO NOT match the tooth spacing on the pulley--- take a close look at the interaction between the teeth on the belt and your pulley happened to us before might have to try several gilmer belts til you get one that fits "just right". Fed 387
