Liked 13 Times in 11 Posts
In my Moroso older Ultimate 2 pan it came with a diamond stripper and that's what I still use........and its easy to imagine why it would work , better than a tray. The Ultimate 2 pan has a full kickout and seriously altered sump......uses tubes through sump to pan rail.
Funny thing is , when I was talking to a "good guy" at Moroso 2 weeks ago , he wanted to sell me a newer pan , one that uses a TRAY........the pan looked much simpler than the pan I have. He told me the newer pan was worth 15 HP..........I didn't buy it . The pan he suggested is below. This pan looks much cheaper to produce than what I have now ( Ultimate 2). ![]() Last edited by joespanova; 03-11-2016 at 10:50 PM. |
I use that Moroso pan as well, with that tray tossed under a work bench.
Ed Wright 4156 SS/JA |
Liked 800 Times in 237 Posts
"That'll never work....." |
Where's the Like button?
Liked 133 Times in 76 Posts
For what it's worth I called Milodon a while back and asked the difference between the screen and the tray type. Their tech preferred the tray and didn't recommend the screen.
Liked 239 Times in 114 Posts
Hamburger Pans, and I bet Stef's Pans sells pieces of expanded metal screen so you can make your own windage screen . What was interesting is this expanded metal was directional , and acted like thousands of louvers. If you sprayed water at a piece of it in the "wrong direction" the water would bounce back at you. Spray water in the "correct direction" and 99% of the water would pass right through .
[QUOTE=ss3011;498185]Hamburger Pans, and I bet Stef's Pans sells pieces of expanded metal screen so you can make your own windage screen . What was interesting is this expanded metal was directional , and acted like thousands of louvers. If you sprayed water at a piece of it in the "wrong direction" the water would bounce back at you. Spray water in the "correct direction" and 99% of the water would pass right through .[/QUOTE
Water is wrong thing to use when testing oil pans, and windage trays only thing it is good for is testing volume oil clings. In wet sump systems it is VERY HARD to get atray that works better than No tray. Worry about a well fiting scraper and large well baffled box with kick out on passengers side and a good pickup that works and doesn't suck a hole in the oil.To test pick up you must use your actual oil. |
