Liked 7 Times in 6 Posts
Is the Milodon Diamond Stripper a good choice for a BBC windage tray?
Should it be mounted close, like 1/4", to the crank? I run a 7 quart pan with 6 quarts in it but haven't used a tray since 2009. I also use a scraper even though I've been told they are a waste of time. I had already made it so it became one of those "It can't hurt" items. Last edited by Ron Gusack; 03-07-2016 at 08:04 PM. Reason: spelling |
Liked 319 Times in 108 Posts
I didn't have good results when i tried diamond stripper tray in SBC
Mike Taylor 3601 |
Thanks Mike. I've read some positive things about the louvered trays. I went from a screen tray to no tray and didn't notice any difference at all.
#4 | |
Liked 13 Times in 11 Posts
Did you dyno back to back between a tray and diamond stripper.........or make track runs and determine any variation in performance was solely due to a different tray / screen? ![]() |
I have been told by two very sharp, well known, engine builders to not use a tray. "Leave it out" they said, and that they always just pitch them. That getting the oil back in the pan faster is more important. I pulled the tray, did not slow down one bit. I have not used one since. That was in 2010. I think maybe you are looking in the wrong place for hp. jmho
Ed Wright 4156 SS/JA |
Liked 269 Times in 99 Posts
What are you doing to keep oil from getting sucked up out of the sump?
Are you using a kickout pan?
#7 | |
He said about nothing sucking oil up out of the pan. This is the first I time I've heard that one.
#8 | |
Liked 319 Times in 68 Posts
What Ed said, haven't used a windage tray in years. Was told by some very good engine builder's oil bounces off them right back to the crank.
Lee Valentine 1661 STK |
Liked 33 Times in 11 Posts
The rear cylinders move a lot of air on their way down so i think it is very important to have some type of baffle obstructing this. You can weld it to pickup tube or attach to pan but just do not want the air blast to have direct path to pickup area. just my opinion.
