Old 02-21-2016, 08:29 PM   #1
Tex013
Liked 43 Times in 25 Posts
Default Who to talk to at Comp Cams re custom cam
Hi ,
I know this isn't class racing but the motor/car is similar .
I thought it was listed a while back but who would be best to talk to at Comp re a custom cam ? This is for a 1962 Belair my friend bracket races - it runs a 409W motor stroked out to 489ci with a Mickey Thomson cross ram intake .
It is lift , valve clearance , limited so I was thinking along the line of a SS type cam . Lower lift but more duration , maybe 268/270@050 max .575 lift . Most shelf cams seem to go huge lift , plus 600 .
Please no referrals to Aubrey .
thanks in advance ,
Tex
Tex013 is offline   Reply With Quote
Old 02-21-2016, 08:59 PM   #2
Liked 1,836 Times in 417 Posts
Default Re: Who to talk to at Comp Cams re custom cam
Tim Cole, or Chris Padgitt. Tell them I sent you.
Old 02-21-2016, 09:45 PM   #3
Tex013
Thanks Alan
Tex
Old 02-22-2016, 09:58 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Just in case you don't know, lift isn't where piston/valve clearance issue come from,piston/valves are closest right around 10*BTDC and 10*ATDC +/- a few*,no where near max lift. W engine could have intake valve to block clearance issues with enough lift and big enough valve diameter though.
Duration,centerline,lobe sepration and how aggressive lobe is, are the factors that effect piston/valve.
Mike Taylor 3601
Old 02-22-2016, 10:41 AM   #5
Run to Rund
Liked 54 Times in 27 Posts
Dean Harvey is also good.
Old 02-22-2016, 04:28 PM   #6
Tex013
Mike ,
yes I know that . we had to cut duration plus some lift out of the cam that is in it now
Thanks for all replys
Tex
