Old 12-02-2007, 08:04 PM   #1
Bill Moulding
Default Re: rear floor material question
Will
I went thru this in 02 with my Camaro. Had it filled with flat metal of the same guage and was told no way. Unfortunately I had discarded all the metal from the original car so I had to buy another one just to get the section from the back to fill in between the frame rails. Would have been a lot easier to do when I was building the car than it was to fill it in afterwards. Good question and good advice from Stewart.
Bill
Bill Moulding is offline   Reply With Quote
Old 12-02-2007, 08:50 PM   #2
will prater
Liked 7 Times in 4 Posts
Chris- thanks for the info. It may help Stewart. The Dart must be slightly smaller. I would like to use the 12.2 x31.25w if I could. With the rails moved or replaced I can.
Bill- I had already cut out the tire well and was going to sell it to someone needing it for restoration. After re-reading my old rule book I noticed the requirement. Luckily it was still in the shop. I was hoping the rule might have changed in the past year.
Stewart- you can catch me Sunday and Monday after 9pm Central at 417-359-8309
Thanks
will prater is offline   Reply With Quote
Old 12-07-2007, 10:05 AM   #3
Stewart Way
Liked 70 Times in 22 Posts
Will
Give me another time when I can reach you. Got tied up on a Home project, sorry.
Stewart
Old 12-07-2007, 10:45 PM   #4
will prater
Stewart, should be home all day Saturday except evening and all day Sunday.
