Old 01-25-2016, 11:22 PM   #1
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Default Re: 3sp to 4sp manual
Originally Posted by Sean Marconette View Post
An SROD is a 4 speed so a 4 speed Jerico, G-Force, or top loader could be used. Depending on the year of foxbody, if it came with an OD trans then a 5 speed can be used. If it's an 82 and older then 4 speed is the only trans allowed. This is stick combos that I am referring to.
Sean
I received conformation today from a Division Tech Director that the above mentioned 4 speeds are approved to use in my early fox.
Thanks for the input.
Shadylane is offline   Reply With Quote
