#11 | |
Liked 2,354 Times in 554 Posts
#12 |
Liked 6 Times in 2 Posts
I race a Sealed Coyote in the Sister class in NMRA. The Engines are not rebuildable for class. If it breaks, rebuild it, sell it, and buy a new sealed one.
We run with the NMCA at 2 events a year. This year was their Freshman year and had 5-6 cars. They should have upwards of 10+ next year. The NMCA class outlaws Stick Shifts. The fast cats are running Metric 200's. If a Stick option was available I would run this class also. So far I feel NO ONE has a "cheater" engine on our side. We have 20+ entries and most of the cars are within 2-3 mph and the fast guys are withing 1/2mph. The racing is cool, close and pays well. Mike Washington |
#13 |
The seals on these engines are not like the seals on the 604 crate engines. The engines are built at GM if you can talk them into changing one only for you Please PM me. LOL.
#14 |
Liked 32 Times in 19 Posts
Tech man said" they Flash them between each round" I assume that's a computer check to be sure no change in program has been introduced by the racers.
#15 |
Liked 22 Times in 22 Posts
Dick, I actually like the spec head deal better because of the reasons already stated. Spec you'd be allowed to work on the engine, and the manufacturer could make the call if the heads are illegally modified. But that's just me. Spec head does work in roundy round, and 360 sprints to cut costs. Bash away.
don,t have one |
#16 |
Randy, I tend to agree with your opinion. Econo Mod rules would allow use of an already built car that was a legal SS or Stocker. Sealed motor class needs construction of a car with its own set of specs. You could not just change motors and move to Stk or SS without more money on chassis.
Also the sealed motor does prevent someone from experimenting with settings, fuel, cams etc but this could be the cost saver area. |
#17 |
The DR525 class rules were written with Stockers in mind. It wouldn't take much to convert one. In fact, the two front runners this year were Camaros built at the COPO build center (CRC).
#18 | |
If someone was cheating in the "Flashing" they are the worst cheaters ever cause the Quick Cats in the class incrementals add up. Mike Washington |
#19 | |
Stockers may have tubs correct? These cannot. can have springs moved but not rails as I understand. |
#20 | |
As far as the rules go, it would probably be best to direct your questions to the NMCA if you are thinking about running a car. |
