#71 | |
Liked 9 Times in 8 Posts
Siamese bore, splayed caps,1 piece rear seal, cast and machined in the USA capable of 4.200 bore. a CGI version will be available at a later date. aluminum will be available first, then cast, then cgi. no price on the alum or cgi yet the cast iron version has NHRA approval
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 12-28-2015 at 01:32 AM. |
#72 |
Bill try here for the block.. We are looking at one for a ss car we have..
http://www.tascaparts.com/engine-blo...qNdRoCh6_w_wcB Scott |
#73 | |
Liked 237 Times in 126 Posts
Dale
#74 |
That is correct Dale, the Cleveland blocks that are nhra approved will be available in a few months. When they are cast and machined they will be added to the accepted products list
__________________ Bill Diehl B200 C/D STK |
#75 |
the ss guys are running the Windsor stuff so I figured the stocker guys could also.. My bad
#76 | |
Liked 304 Times in 102 Posts
I recommend for you to save your money on the rings and give Greg @ Tri City a call for a set of rings that WILL work and cost 1/3 of what you are talking about. Mike Taylor 3601 |
#77 | |
The currently available Ford Racing BOSS 351 is a Windsor. You could run it in SuperStock but not Stock. Dale
#78 | |
Mike Taylor 3601 |
#79 |
Liked 7 Times in 5 Posts
The current Windsor Boss 351 blocks are available in both 9.2" and 9.5" decks. They also have the Cleveland main size.
Roland |
#80 |
They even have a 9.200 dh with 302 mains.. They are harder to find but available... Talked to the guys at ford the other day..
In the early 90,s when we ran the 351 C in GT/B we had a lot of issues when they really started making power. We went 9.30 at almost 148+ in 1994 with this combo with a G force trans that had to be clutched on all shifts.. So they will make a lot of hp.. I had an entire kit with all the part numbers and all for ford to approve, a Windsor block for the Cleveland then and ford never submitted it to NHRA. I already had NHRA ok with it if Ford had submitted it as a replacement. Scott |
