Old 11-22-2015, 08:39 PM   #1
getdenet
Default 1985 mercury capri. Stocker question
For Stock Eliminator Does the NHRA allow automatics in the 1985 Mercury Capri with carbureted 302? Or can only be run with a standard transmission? Thanks in advance
getdenet is offline   Reply With Quote
Old 11-22-2015, 09:10 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: 1985 mercury capri. Stocker question
stick only.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 11-22-2015, 10:59 PM   #3
Rory McNeil
Liked 1,102 Times in 301 Posts
Like Bob said, they are stick only as long as you are using the 4 barrel carbed 5.0 HO engine. You could get a Mustang or Capri with a 5.0L engine and automatic transmission in 1985, but it used a CFI throttle body fuel injection setup. 1986 Mustangs look almost the same as 85, and you can use an automatic or a stick, as Ford used the same engine either way, but they were all EFI by then.
NHRA 6390 STK
M/S 85 Mustang
