Old 10-03-2015, 10:07 AM   #13
Jim B
Default Re: Valve springs 340 Stocker Engine
Originally Posted by James L Miller View Post
Sorry if I am ignorant on Stocker engine builds, but the spec I have for a 1969 340 calls for a .462" intake and .473" exhaust lift. Are people using a "square" lobe to loft the valvetrain off the lobe to get the .520" lift? I have an old Cam Dynamics 340 Stocker cam from the 1970s and it has a flattened nose on the lobes. I have some newer cams from Lunati and Bullet that have a more regular lobe appearance.
He did say the .520" number was for lift AND coil bind. Allowing .060" for coil bind clearance would put the lift number at about what you had....
Jim B is offline   Reply With Quote
