Thanks Bob. Anyone else with any suggestions? Come on go fast guys, I just need alittle spring pressure, that's all. LOL
Mike,
Why exactly will the 1409X work? Need to know so I have an idea what to look for. |
#3 | |
Liked 68 Times in 41 Posts
573 346 1360 he's a go fast small block mopar guy
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Thanks for the replies.. Turbo, the reason the 1409X won't work is, the inside diameter of the spring is too small, I need at least 1.00 inch and when you squeeze that spring down to 1.680 installed height and then collapse it down .520 for cam lift and coil bind clearance it is at 1.16 and it says it coil binds at 1.19 inches. Kelly, thanks for the advice, I'll call Brad tomorrow and see what he says. If you don't care about the rule book, lots of springs can be made to work, but it says the head cannot be modified in anyway to install a valve spring. To me that says I can't cut the step off from the guide out to the valve spring pocket to accept a smaller inside diameter spring.. Also the valves must be stock demensions, so that leaves out installing a longer valve, which would also make things easier. The mopar short spring and installed height is just a big problem. Thanks for the replies and if anyone else knows what others are using, let me know, something has to work!! Mike
Liked 2,462 Times in 694 Posts
Mike:
I have fooled around with the expensive NASCAR springs and latest Beehive spring with the new trick camshafts. I went back to my 25 year old profiles and the ISKY springs again about 170 on seat and run just as well or a little better That being said......My boy runs a complete Van Lant engine with all the new tech stuff ( We both believe Brad is the premier small block mopar guy to go to!) and is about .03 to .04 slower any given pass each time out (with identical twin Demons) which is still pretty good. He doesn't mind working constantly on his car and may find something someday.....Just not the last year or so. I am too old and my back is too bad to struggle with all the valve train problems that the big spring pressures/ new cams profiles / Ceramic lifters generated for me for little or no perceptual gain and a LOT of money! As Always you results may vary!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 10-05-2015 at 05:55 AM. |
xx
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 10-05-2015 at 05:54 AM. |
Thanks for the reply John, see you in Vegas. Mike
#8 | |
Liked 25 Times in 16 Posts
Mopar 2 Ya! |
#9 | |
#10 | |
Liked 704 Times in 218 Posts
