Liked 369 Times in 127 Posts
OK.
I can see where the footbrake might be quicker (e.t. wise) than the t.b. then.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Depends on the combo. Mine is faster off the trans brake. About a tenth.
Ed Wright 4156 SS/JA |
Liked 747 Times in 136 Posts
My car has always been faster footbraking from an idle than transbrake off the two step (~3,000 rpm). But mine is a carburated combo. I've always chalked the difference up to all the nasty raw fuel flowing through the manifold, ports and cyls while the throttle was wide open and the car was at only 3,000 rpm coughing and barking on the two step. then when you let the button go there is a period of time where its very rich until all that mess cleans up. Now that I have a logger, sure enough the O2 graphs show this exact thing to be the case.
I suspect the guys with fuel injection don't have the same problem, since when you are on the two step, the program is also limiting fuel as well???? |
I have never drove a transbrake car, but does the t.b. preload the car's suspension like foot braking does ?
Or is the suspension relaxed while on the brake ? During heat of summer leaving off of the t-brake and a relaxed suspension the converter flash stall will often cause my small tires to spin causing a couple hundredths variance in the 60'. But when the track is below 115 degrees it will dead hook and feels like it's going to break the windshield due to the torque. It is only 2 or 3 hundredths quicker in the heat. I wish I was better at footbreaking because the car leaves so much better. With a preload on the suspension the leaves level and real smooth. where as the brake it lifts the driver side wheel about a foot off ground and is all twisted. Like I mentioned in the heat ET's are real close but in cool weather there is about a tenth difference. Just wish I was a better footbreaker, it agrees with my car much better. BTW, this is a 3400lb wagon converted from stock which runs in the low elevens and still using 9" slicks, causing my traction issues in the heat. |
Liked 7 Times in 6 Posts
So it makes sense that a lower rpm launch in a footbrake car could make RT's quicker? Sometimes I increase RPM's and the RT gets worse. I never know if it's me or the car.
Kinda off topic, but what do trans temps do to RT's? |
