Old 07-22-2015, 12:11 PM   #9
brian schuetta
Liked 28 Times in 15 Posts
Default Re: 82-92 F body brake help
Did you drill the hole for the Clevis to attach to the brake pedal lever higher than stock? These cars never had two holes drilled in the pedal lever like older ones that came with manual and power brakes. I drilled mine around an inch or so higher, copied a 69' Camaro dimension. I used four primary shoes and I think 7/8" or 1" brake cylinders from a 69' station wagon.
brian schuetta is offline   Reply With Quote
