Liked 73 Times in 24 Posts
Since Danny built it, I am ruling out the air door to loose. I would try a new choke pull-off, I have had several of them go bad and cause the same issue. Pull the vacum hose off and push the arm in, with the arm pushed in hold your finger over the vacum port. Let go your finger off the vacum port and make sure the arm comes out smoothly. If it starts coming out and then hangs up for a second it's bad.
Monte Howard 3209 STK, 3208 SS |
#2 | |
Liked 2,024 Times in 607 Posts
Mike Pearson 2485 SS |
Liked 3 Times in 1 Post
In the instruction from Danny that come with The carb it said
that the brass plate fit in a machine groove in the carb top and I have double check the plate and it is in the groove. If I find a answer I will post it. Thanks for everybody's help Bob Keller |
Don't you guys think 6 psi. of fuel pressure is a bit low? We had a Dean Oliver prepared carburetor and currently have a Hedworth prepared unit and we ran both carbs. at 7 psi. and both perform nicely. Is it possible momentary fuel starvation is occurring considering a Q-Jets float bowl is so small?
Just a thought.
Nelson Kowal Stock 345 Last edited by njk53; 07-13-2015 at 12:56 PM. |
Liked 6 Times in 2 Posts
Fuel Pressure is related to the size of needle and seat, and float settings and of course demand. I need to run mine at 5.5 for best operation , anything over 6 and - too many issues
Mike Semeniuk 632 GTMA |
Mine runs good at 6 lbs too.
Liked 56 Times in 31 Posts
I am running a Joe Scott at 7 psi with no issues.
My Ashley was also running at that same pressure.
Thomas NHRA 1959 E/SA |
