Liked 21 Times in 13 Posts
Ok, so on my e-body I carefully installed the door bar to clear the door handle and somehow didn't give any thought for clearance for the window crank being able to revolve. Obviously I can open the door to roll up or down the window. Is this legal ? I may redo the door bar anyway, just wondering how this is viewed. thanks
Brian Carpenter Stock 1358 |
Liked 9 Times in 3 Posts
on gm cars I have used the vent window crank from a 67 Camaro. it's much smaller the than the window crank.
Mark Markow 171 ss/tb |
Liked 11 Times in 8 Posts
would converting it to power windows be out of the question? It's easily done on most cars...a bit more work but more convenient. Joe
Joe Buchanan SS/BX 3117 |
Liked 237 Times in 126 Posts
Same issue on my 68 Mustang. I put an aftermarket crank from Lokar on it mostly for looks and the stock one was shot. I have to pop the door to crank the window and watch where it is when I close it, but it's mostly a race car.
The trick is to close the door with the crank off and the window up, then position the crank so that the window can be cracked up and down to cuss at the starter without opening the door. Dale
#5 | |
Yeah, you never know when you need to yell at someone. haha
an electric motor would do, need to think about that. maybe the smaller crank would work Quote:
Liked 292 Times in 101 Posts
I have to have my windows working,maybe it's just me but can't stand to drive something that window or door doesn't work correctly,if I had to open door to roll down window,it would aggravate me LOL. other pet peeve is,it drives me nuts to drive a car on the street that is missing side or rear view mirror.
Mike Taylor 3601 |
I had & kept my power windows. Very nice to be able to get some air through the car while strapped in. Just roll them up as I roll into the water box. I could not reach across to crank the passenger side up while strapped in. Much easier all around. I have weighed both power & manual doors. Within 2 lbs of each other.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-26-2015 at 08:28 AM. |
Without a doubt, it doesn't make sense to put a ton of money and time into a car and can't roll down the dang window. I have a S&W roll cage kit in it, and while it's a nice cage, the door bar is a PITA to climb over. I think I'll put a swing out kit on the drivers side and make sure it clears the handles. Probably should have listened to one of my "advisers" and put in the swing out bar in the first place.......
I have swing-out bars too. Makes working inside, under the dash, etc, possible. I put the pins in for tech, and before getting in to run. You get used to crawling over the bars eventually.
Ed Wright 4156 SS/JA |
I'm not going to question the safety aspect of the NHRA rulebook as I know the cage specs come from the folks at SFI, but you just can't have a crash bar that crosses the designated body points in the specs and operate a manual window crank. An electric kit for my Mustang would set me back something like $700. It's a 68 coupe and that seems to matter somehow.
Dale
