Old 06-19-2015, 03:07 PM   #1
bigfoot584
Default Re: brake pressure
Chris thanks for chiming in, not sure what I
was thinking at the moment but I took 1800
for psi instead of rpm's .
Senior moment that was it, ah that's the ticket.
bigfoot584 is offline   Reply With Quote
Old 06-19-2015, 03:10 PM   #2
Chris1529
Liked 70 Times in 29 Posts
Now that I look at it again, he may be talking about brake psi.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-21-2015, 06:00 AM   #3
THE LEGEND
Depends on how much. 100lbs won't slow you down but 500 may.
THE LEGEND is offline   Reply With Quote
Old 06-21-2015, 12:04 PM   #4
Eman
Liked 133 Times in 76 Posts
I would think that the harder you're pushing on the brake pedal the slower your leg would be to release. I've thought of putting a brake pressure gauge on my car just so i would launch at the same brake pressure consistently. I have leg problems and the "feel" in my left leg isn't consistent, unfortunately sometimes uncomfortable and painful. What brake pressure do people with gauges generally shoot for while staged?
Old 06-21-2015, 01:52 PM   #5
Joe DeMarzo
Liked 113 Times in 9 Posts
I leave at 1800 rpm, no brake pressure gauge in this car. I had one in a previous car and left at 800lbs every time. I left hard on the converter in the other car and wanted to be consistent. At 1800 it is like being at stop light, lol.
If brake pressure doesn't change reaction time than why do we care if we leave at the same brake pressure???
Thanks for all the insights
Good stuff.
Joe DeMarzo 1317 STK
Old 06-22-2015, 01:43 PM   #6
Signman
Liked 269 Times in 99 Posts
Joe I always over simplify: The further you step down on the brakes the longer it takes to get to the point where they are overcome by engine power at the same RPM when you swap feet.
Raise the RPM step down harder to hold RPM is closer to Stall should improve RT.
In the case of cars that need to pull the wheels out of the beam to cut a light leaving lower may hit the converter harder and Pick the tires up quicker, rear suspension also plays in to this as well tire pressures.
Old 06-22-2015, 08:50 PM   #7
George Mirza
Good stuff.
Hi Joe,
Brake pressure consistency comes into play when using a brake pressure activated two step. I believe when foot braking, once you put the gas to the floor no matter what the car is going to move, at that point any brake pressure will be over come.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
