Old 06-10-2015, 09:45 PM   #1
Bill Baer
Default Re: BBC Dry Sump
If I understand your question you want to convert a wet sump engine to a dry sump configuration.
You'll need to remove wet sump oil pan the stock type oil pump and replace it with a block off plate on the rear main cap.
Then install and plumb the dry sump pan , pump , pump drive and tank.
