Old 05-25-2015, 05:29 PM   #1
Default Re: Motor won't start after 2nd rd?
If it cranks but will not start, as others said, check the ignition switch, the coil, the coil wire, the pick up (what ever style, magnetic or optical, at the crank or in the distributor), and the ignition box.
Old 05-25-2015, 10:21 PM   #2
Keith 944
Keith 944's Avatar
Liked 1,882 Times in 578 Posts
Hey Cal it did start 3rd round so it must be getting better, I would leave it alone....lmao
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-26-2015, 11:33 AM   #3
FED 387
Liked 333 Times in 180 Posts
I would swap out first the coil----what coil and part number are you using?? next swap out the ignition box-- what box and part number are you using--- FED 387
