Liked 408 Times in 35 Posts
Still at the paint shop.
George Wright https://9500rpm.com |
Paint is just about done. Bumper covers, door handles, rockers, etc. will be painted in the next few days. Should have it back to my shop by Saturday.
Liked 84 Times in 42 Posts
Looks good George. For a whole body you got that back pretty quick. Then you can start the fun stuff where you put things in for the last time. We are just finishing that phase with our car and should have it at the track in a week and a half.
Bob |
Looks good...
My CJ came back from the paint shop several weeks ago. However before I started working on it I helped Jimmy finish up the Mule. I also finished putting the clutch-less 4 speed in my Probe.
![]() The Mule is the 2010 Ford Racing test car. Joel (Joel's on Joy) purchased the Mule from Ford Racing. Jimmy Ronzello has partnered up with Joel on the Mule and will be racing the Mule at NHRA events. ![]() The Mule was completed June 15th. ![]() Last minute changes and lettering prior to Norwalk national event. ![]() Installing new clutch-less 4 speed in the Probe. ![]() The Long Shifter on the clutch-less 4 speed has 2 rods on each fork. Now back to the project at hand. ![]() Back from the paint shop waiting for the Mule to be completed so I can move the body over to the assembly shop. ![]() Roll cage was painted a dark charcoal grey. ![]() In the assembly area. ![]() I had seat braces water jetted out of 1 inch aluminium plate. ![]() The a aluminium braces support the front of the Jaz aluminium seat.
![]() ![]() Tail lights, rocker panels, weather stripping all installed. ![]() Door glass installed. Door harness installed and power windows tested. ![]() Seats located and bolted in temporarily. Main wiring harness tested and installed. Big Stuff ECU and electrical components mounted on plate attached to roll cage. ![]() Headlights installed. Gas cylinders installed. No need for a prop rod to hold up the hood. ![]() Deck lid and rear bumper beam installed.
Liked 19 Times in 12 Posts
Very nice!
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
