#11 | |
Sponsor
Liked 9 Times in 1 Post
#12 | |
Liked 4 Times in 2 Posts
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
#13 |
Liked 2 Times in 2 Posts
Any Dana experts have a suggestion, for a 1976 Ford housing, that houses 3.50:1 only? We built a 4-linked street car for a friend and would like to have a 4.10-ish range ratio. With the tall rear tires and 3.5 it sure does good on the Interstate but rarely leaves city streets.
#14 |
I did not know their are 4 different weight Dana 60s. Does know how to tell
them apart. The ones I have used are center sections out of 80s Trucks with Chrome Moly Tubes.
#15 |
Liked 334 Times in 181 Posts
no expert here but from my experience there is a HD cast into the housing look for it top of rib left side of the "heaviest" Dana 60 ,otherwise the diameter of the axle tubes determines the lightness of the housing with 3 inch tubes being the heaviest---the OEM centers are really the same---supposedly there is a "501" Ford Dana 60 that is the lightest but I do not know what vehicles it came in--FED 387
#16 |
Liked 62 Times in 17 Posts
I've been considering replacing my 8-3/4 with the Strange 60 housing. Pricing seems good.
#17 |
Liked 68 Times in 26 Posts
hi, the four dana 60's are, lightest is in a 67 to 72 ford 1/2on pickup, next is mopar b and e body cars, next 3/4 ton pickups and heaviest is 1 ton pickups. I found an article in a four wheeler magazine years ago. they listed the dana's . the 1/2 ton ford one has passenger car ends on it, easy to spot. it weighs 32 # more than 8 3/4 . has 3 " tubes. also, I found a dana 60 from a J 20 jeep pickup. it has 2 3/4" tubes on it , passenger car ends as well.
#18 |
Liked 242 Times in 81 Posts
If you are building one for a race car. Do it the right way. Strange S60 center molly tubes, 40 spline ultra lite axles from MW Aluminum spool back cut ring gear. It will be bullet proof and only about 20lbs heavier than a back braced ready to run 8 3/4 that will break anyway. If you are worried about changing gear ratios at a race it is really quite simple. With the S60 you have adjusters for back lashand preload. You set your pinion gear up with bearings and shims. You can change gears in under an hour.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
