Old 03-17-2015, 08:10 AM   #15
henrys57wagon
henrys57wagon's Avatar
Default Re: GM 8.5 ten bolt crush sleeve
No.
The 12 bolt goes from inner to outer inside bearing races.
The 8.5 (and the 7.5) seats against a shoulder on the pinion ,and loads the outer race only. The 8.8 Ford has a similar setup.
Years ago I made solid spacers for 12 bolt's and when I was going to put an 8.5 in my HenryJ I looked at making a solid spacer but have it go from bearing to bearing. Went to a 12 bolt instead.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
