Old 03-02-2015, 03:08 PM   #1
GTX JOHN
Default Re: U/SA help request
Look to see where on track you lost the time.
I have been having problems with MSD Coils
a lot in last couple of years. It reflects more on back 1/2
numbers and particularly MPH. I would borrow another coil
to try. Also Electrical stuff and connections slow the car down and
I would go thru all related wiring.
John Irving
741 Stock
741 Super Stock
Old 03-02-2015, 03:27 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Mike,
My car has pulled that on me. I thought I lost a cam, everything checked out fine with the engine and leak down. I could not find anything mechanically wrong, and pulled all of the grounds and cleaned them. And magically the car was back to normal. What I found out was a bad ground was the problem. The data logger never showed a voltage issue or fuel pressure issue. But 3 passes in a row it kept slowing down more, and did not sound any different, after resorting to everything but mechanical it had to be an electrical issue.
Good luck
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-02-2015, 03:49 PM   #3
Lou Jeffery
Smile Re: U/SA help request
My 302 2v Maverick slowed .4 when I installed the correct legal carb. instead of the 351W carb that we thought was correct. That said we did have a issue with failed camshaft lobes that did not have a audible miss just really laid down. Louis Jeffery
Lou Jeffery is offline   Reply With Quote
