Old 02-22-2015, 06:37 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Any performance difference in Sunoco Purple?
Has anyone seen any differences with the new fuel this year? Performance or other wise effected? Do you need to rejet or modify timing in anyway? Any help or advice is appreciated
Old 02-22-2015, 10:34 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Any performance difference in Sunoco Purple?
You need to be a little more specific. Sunoco is the official fuel of NHRA and IHRA, but any performance changes or jetting adjustments may depend on which brand and octane one used before as well as the engine combo. All of the same fuels are still legal as before in the sportsman classes. One doesn't have to change brands, but Sunoco will probably be easier to get.
I've used Sunoco Purple.....about forever, in brackets and IHRA, and have been happy with the performance and consistency. I'll stick with it when I get into NHRA as well.
LOCOMOTION Racing
Old 02-23-2015, 10:42 AM   #3
Mike Croley
Default Re: Any performance difference in Sunoco Purple?
Depends on which brand and octane you were running. Jetting should not be an issue going from one 110 brand to another. Or timing either. The only big difference between leading 110 octane fuels is the Motor Octane.
Sunoco 110 is 106
Vp 110 is 107
Renegade 110 is 108.5
Mike Croley is offline   Reply With Quote
Old 02-23-2015, 03:12 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
Rockett 110 also has motor octane 106.
Old 02-24-2015, 12:34 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Better take a look at the specific gravity of each before you conclude no jetting changes are needed.
Adger Smith (Former SS)
Old 02-25-2015, 12:02 PM   #6
Mike Croley
Going from last years official brand of 110 to this years official brand shouldn't require major changes. But here's a rule of thumb for jetting when changing brands or blends of race fuel. The rule of 10.
Example... moving from a fuel that has a SG of .710 to a fuel that has a SG of .718 would require no change in jetting.
Moving from a fuel with .710 SG to a fuel with SG of .721 would require a jet change of 1 jet size.
Moving from a fuel with a SG of .710 to a fuel with a SG of .730 would require a change of 2 jet sizes.
The same rule would apply going from a larger SG to a smaller SG.
