Old 03-06-2018, 04:18 PM   #1
geoklass
Liked 11 Times in 4 Posts
Default Re: Optional Super Stock Indy 1961
I'd really like to learn more about that event but photos and detailed coverage is hard to find. Any help you guys may offer is appreciated.
Jody, If you really want to learn more about this era, there is a very good book available. The title is - Super Stock - Drag Racing the Family Sedan, by Larry Davis. The book was printed in 2010 and is very good reading with lots of photos. It should still be available from Amazon or through your local book store (Barnes and Noble) or such. I don't believe the book covers the event in question with much detail but covers the era (55-68) very well and can answer many questions you might have.
NHRA has always been careful about insuring that the factories did not alter or change components after they were initially listed as "permitted" for the S/S class. 1961 was a strange year for S/S, for a couple of reasons. First, they permitted cars to compete in S/S even if they did not originally have the legal engine for S/S. For instance, although the Chevy 409 engine was legal in '61, it did not need to be a factory produced vehicle. In effect, if you had a '61 Chevy with a 6-cylinder engine or a 283 or 348 engine, you could purchase a 409 engine from your dealer and install it in the car yourself or have it installed by the dealer. By 1962, if I remember correctly, it clearly stated that the "legal" engine had to be "factory installed". And NHRA did not know what to do about the parts that came out during the year, that had not been available at the beginning of the year. In the 409 case, Chevy offered a different cam, heads and intake manifold prior to the NHRA Nationals in 1961. Had that been done prior to the Winternationals, it would not have been an issue, but it was offered in mid year, as "optional parts", and not "available as factory installed".
Pontiac, Ford, and Dodge / Plymouth followed suit with mid year non-factory installed optional parts. NHRA created the "Optional S/S class", for that one event only, and it was never done again.
I seemed to recall a similar problem at the '62 NHRA Nationals, with the Chevy guys running "optional" engine equipment, but it's a little hazy now as to how that got handled. Maybe they ran in F/X, I can't remember.
An interesting situation happened at the NHRA Winternationals in 1963. Several Chevy racers arrived with Z-11 cars, Pontiac racers with the Swiss Cheese Panchos, Ford guys with plastic hoods, etc., etc. All Factory backed cars, but those components had never been presented to NHRA for classification. These racers expected to run in the S/S class, but NHRA said no. NHRA created the "Limited Production class" (L/P) for that one event only, and it was never done again. As it turned out, neither Chevy or Pontiac had produced enough vehicles to even qualify as "stock", and these cars were eventually classified as "Factory Experimental" at later NHRA events. Both Chevy and Pontiac built the full size cars to run in S/S, not in F/X (Pontiac already had the 421 Tempest for F/X), plus the anti-racing ban hit the GM Divisions.
Ford went ahead and did build enough '63's with light weight hoods and doors to qualify for S/S, but that did not happen in time prior to the Winternats. I never did follow up on the Mopar guys and their issues.
NHRA cleaned up their S/S rules after '63, added clarifications where needed, and created good connections with the factories, and the issues of '61, '62 and '63 did not come up again, as far as I know...
geoklass is offline   Reply With Quote
Old 03-09-2018, 02:53 PM   #2
geoklass
I was looking at my old NHRA Rulebooks this morning and found the wording used in 1961 that led to the O/SS class at the NHRA Nationals that year. In the '61 Rulebook for Stock Class (under ENGINE) it states as follows: "Engine in each car must be of the specific type, year and make as the car in in which it is being run." This line is how some racers were able to install a 409 engine in a Chevy that was not factory installed when the car was first produced. It goes on to say, "Engine equipment other than that regularly produced for assembly line installation by the manufacturer will not be permitted." That line is why NHRA did not let special over the counter factory parts run in S/S, and created the Optional S/S class for the Nationals.
This was rectified in the 1962 NHRA Rulebook. In the Stock Class section in bold print: "All cars in stock class manufactured after June 1, 1961, must be factory assembly-line produced and generally show-room sales available."
In 1962, the FX (Factory Experimental) class was introduced. It read as follows: "The Factory Experimental class is for stock automobiles that use manufacturers' optional equipment announced on or after June 1, 1961; optional equipment that is not necessarily factory assembly-line installed show-room sales available."
This same sentence was also used in the '63 NHRA Rulebook. What the factories did (especially GM with the Z-11 Chevy and Swiss-cheese Pontiacs) was to produce a few cars that had this "optional equipment" but WERE factory assembly line installed, hoping to be able to get them into Super Stock instead of Factory Experimental. Had they continued to produce those cars in quantity, NHRA would have most likely declared them to be S/S legal, but there so few made (57 Chevy Z-11 Impalas and 14 Swiss Cheese Pontiacs), it did not happen. When they showed up at Pomona in February '63, the so-called factory cars were all lettered with S/S. but NHRA declared them to be ineligible for S/S, and created the Limited Production (L/P) class for them instead. I was there and remember quite well the meeting between the factory reps and NHRA (it was NOT a quite meeting). Ford eventually did produce enough cars and NHRA did permit them to run in S/S class later in the year.
These were great times, the "Super Stock Years", when it was factory vs. factory. It's long gone now, and will never return like it once was.
Old 08-01-2018, 12:10 AM   #3
DeuceCoupe
Liked 48 Times in 44 Posts
@dplotkin
You might like this thread on the Hagerty site, 7 Muscle Cars before the GTO LOL. See the commenter @sonoramic, he used to run a 383/330 sonoramic car back in 1960-61
https://www.hagerty.com/articles-vid...before-the-gto
Weertman's book is also excellent - I was at SAE Detroit when he presented his history of Mopar engines in ~2004 or so. It was standing room only into the hallway.
Old 08-28-2021, 11:57 PM   #4
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
I've been combing thru some of these old threads in this section. Noticed that a lot of old threads have been ruined because the pics that were posted no longer work.
I have pics of 3 Pontiacs that have OS/S on 'em.
Name:	1 - OS-S Trophy .jpg
ID:	58526   Click image for larger version
Name:	2 - OS-S Winner & Rec Holder .jpg
ID:	58527   Click image for larger version
Name:	3 - OS-S Union .png
Name:	4 - OS-S Passion .jpg
