Old 01-25-2015, 11:36 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ol' Fart's Firebird Fantasy
OK, THANKS ! That clears it all up, except for one thing. I just wanna be sure, so I'll ask again. Is there no limit to the amount of weight you can remove in order to meet the min for the next higher class ?
No restrictions other than you will reach a point depending on the platform where there is simply no viable way to remove any further weight. Our '67 Camaro for instance...we had to add 20 pounds to meet minimum weight for E/SA which means I would have to find around 120 pounds to remove in order to arrive at D/SA minimum. Our car still has the factory seats which are a tad on the heavy side...aftermarket seats would help to a point, but it would be a struggle to find more in this particular car.
Rich Taylor
I/SA - 321
