Liked 133 Times in 76 Posts
Look at Competition products website. They have a great assortment of springs available at a good price. I use Howards stuff in my motor.
Is this a hydraulic or solid? What springs are on it now? The other BIG thing with flat tappets is the oil you use. I have used Valvoline VR-1 10w-30 and now use Lucas Hot Rod oil 10w-30. |
#2 | |
Much depends on the cam and your intentions. I've had good luck on hydraulics with the basic Z-28 style spring. Most will be fine up to 6k RPM. If possible remove and ck your springs. Installed height is very important. You can boost the pressure a little by shortening installed height just make sure you have enough clearance for coil bind. Be careful about too much pressure or you'll wipe out a lobe.
