Old 01-08-2015, 04:36 PM   #1
SSDiv6
Liked 1,568 Times in 579 Posts
Default Re: SS piston dish
Originally Posted by Mike Graham View Post
The application is a low compression 460 Ford with a 15 cc dish. The dish is like a sideways D. The dish was too shallow by about .005. The "fix" was to plunge cut what I can only describe as a secondary valve relief near the intake relief. The cut is perpendicular to the piston top and half into the quench area. As you know this is a canted valve motor so this cut looks mighty strange. Now the flat side of the D has a bubble in it. Mechanically I don't see any problem, but visually it is obviously different.
The dish is correct depth and correct cc.
Don't have access to camera at this time.
Is the plunge cut part of the valve relief? If it is, It could be considered as part of the valve relief.
Old 01-13-2015, 03:38 PM   #2
tj310
I have a similar question about this although the motor I'm working on is Chev. The rulebook refers to design pattern , surely the valve notches could be figured into the dish CC s ? ---Trevor
Old 01-16-2015, 11:58 PM   #3
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
A dish could be 40 holes drilled in the piston. Unlike stock, the piston just need to be measured legally for some kind of dish.
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 01-17-2015, 06:29 PM   #4
Bob
Unless something has changed in the 2015 rulebook, 40 holes weren't and wouldn't be legal. The rule has always been (straight from the rulebook):
"Replacement pistons permitted, provided they do not increase
stock compression ratio and retain overall design pattern as
specified by automobile manufacturer. Dish pistons must retain
half of original depth, and original diameter and configuration."
That is to say, yes you need to keep the original dish design. And you need to keep at least half the original depth. The remaining CC lost by a shallower dish can be acquired by valve reliefs.
Bob is offline   Reply With Quote
