Dave,
take the sending unit out and cut off the fuel lines on both sides, then drill it out for a bulkhead fitting either # 6 or # 8 depending what size line you want. Use steel tubing to replace the inside line, flare the end and secure it using a tube nut.
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 1,568 Times in 579 Posts
In lieu of steel tubing, I would recommend the use of aircraft aluminum tubing. Does not corrode, lighter and absorbs vibration and harmonics without breaking at the fitting.
Liked 772 Times in 192 Posts
I have also used copper tubing bent to shape and soldered in place through the flange for the pickup tube. I believe GM solders the steel tubing in place from the factory. You can even solder the float sending unit onto the copper tube and have the stock fuel gauge work.
#4 | |
Liked 346 Times in 126 Posts
Dave |
