GT/HA '66 Plymouth Belvedere, 426 Street Wedge, 3,675 lbs.
2.77 first gear ratio, 4.89 rear gear, shifting @ 6,500 rpm, 7,500 rpm at the finish line. 1.44 60', 4.35 @ 330, 10.80 @ 122.00 mph. Problem is it runs out of steam at the top of the first gear. Running an Edelbrock Super Victor with a Carter AFB 585 cfm, fresh Product Engineering 9500 Fuel Pump and 4 port regulator. What do you guys think? |
#2 | |
Liked 327 Times in 121 Posts
Liked 319 Times in 68 Posts
Try shifting 1-2 at 6000-6200 see if it goes faster.
Lee Valentine 1661 STK |
I was thinking the same thing. I always have to get out of low gear much sooner than second.
Ed Wright 4156 SS/JA |
Liked 138 Times in 51 Posts
Just to be on the safe side, if clearances and other factors allow it, try upping spring pressures a bit. It's better to have a LITTLE more than needed than a little less. Do some research on what your overall engine combo should like in springs.
Being a long stroke big block, it could work better with less rpm, as suggested.
LOCOMOTION Racing |
Okay, I'm good with lower rpm, but I'm thinking the intake has too much plenum and runner, agree?
Too much plenum or runner cross section won't cost power at higher RPM. My experience has been the other way around.
Liked 320 Times in 102 Posts
426ci + 525 CFM don't = 7500 rpm at the end or 6500 rpm on the shifts..
Just sayin' PS: But I could be wrong......................
If I may.....Try breathing through a straw (small carb), then try breathing through the cardboard spool out of a paper towel roll (big carb). You can only take in so much air in so much time through a small hole. The restriction doesn't allow you (or the engine) to breathe enough volume quickly enough to satisfy the needs. (High rpm or you running.)
LOCOMOTION Racing |
