Old 10-18-2014, 12:31 PM   #31
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Most expensive, least helpful and useless advice
Bought a quadrajet from carb builder x and I was told to buy from carb builder y. X was slower front half and Y was slower in back half. Same ET.
Take the rubber seal off where hood meets firewall. Found out it wasn't legal. Put seal on and it went faster.
Had square lipped seal on brake calipers. Put the round type seal on and have less drag. No ET gain.
I quit at 8 converters for one motor combo.
Monte has more frontal area then Camaro so you need more gear. Went from 5.67 to 5.86 nothing gained but a couple more RPM's at finish line.
Old 10-18-2014, 10:11 PM   #32
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: Most expensive, least helpful and useless advice
Snake oil, fancy plugs and wires and yes those damn converter things Best advice always came from grumpy old grey haired guys Great topic
Kevin
SSGN is online now   Reply With Quote
Old 10-19-2014, 09:28 AM   #33
goinbroke2
Liked 393 Times in 153 Posts
Smile Re: Most expensive, least helpful and useless advice
Kevin
So from anybody in the pits? :O
goinbroke2 is online now   Reply With Quote
Old 10-19-2014, 11:56 AM   #34
Greg Hill
Liked 279 Times in 68 Posts
I've learned just as much from what doesn't work as from what does work. If you don't try things you don't advance.
Greg Hill 4171 STK
Old 10-19-2014, 09:43 PM   #35
69Cobra
Liked 2 Times in 2 Posts
That's the best post in this thread!
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 10-20-2014, 08:10 AM   #36
Ed Wright
Ed Wright's Avatar
Exactly!
Ed Wright 4156 SS/JA
Old 10-20-2014, 09:14 AM   #37
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Recommendation from a highly respected manufacturer, for an uncontrollable "square" intake cam lobe. Then further recommendation for "glass-like" tool steel retainers. Then further recommendation for beehive springs with smaller "glass-like" tool steel retainers.
A yes, these recommendations have kept my car in pieces for years !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 10-21-2014, 03:30 AM   #38
older racer
Liked 68 Times in 26 Posts
hi, I noticed mention concerning rings earlier, also the" trick of the week camshaft" . seen lots of those, lol
older racer is offline   Reply With Quote
Old 10-22-2014, 11:05 AM   #39
glen myers
glen myers's Avatar
Wait - what- you have to have hair?
Give up Rusty just finish bolting it together and go!
hahaha
glen myers is offline   Reply With Quote
Old 10-22-2014, 12:34 PM   #40
Jim Caughlin
Liked 805 Times in 245 Posts
This is somewhat of a variation on your question but over the years I've learned a lot about what you can get away with by looking at various things on race cars that have been in my shop that I never thought would have worked, usually things that I thought were way too flimsy to survive. An example was an 8 second full bodied car that had 1310 ujoints, a 3" alum driveshafts and a 10 bolt Chevy rearend, all with a ton of runs and no significant breakage. I think what happens in a lot of cases is a bracket car that progressively gets faster and lightweight parts don't get upgraded. Nice to learn lessons from someone elses torture testing.
That being said, I have a boatload of 'good idea' parts in the corner that didn't pan out. As most class racers have exhausted the easy performance improvement ideas, it comes down to a certain amount of educated trial and error. Someone once told me that at this point, if you get $1 worth of performance for every $3 spent, you're doing pretty good.
Jim Caughlin
SS 6019
Jim Caughlin is online now   Reply With Quote
