Old 10-15-2014, 09:47 AM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: roll cage decesion for the Super 10
Larry, if you already have the means to bend the tubing I'd suggest you bend your own. I've installed quite a few "kits" none of which fit exactly as I'd have liked, the only way to gain experience is to practice. Yes you'll prolly scrap a few pieces but you'll learn alot. I've used a couple different software programs over the years that have really helped mainly when trying to make a bar that requires rotating in the die (like a one piece A pillar bar) of course math is not my strong suit so the software really helped me. I can almost walk the pits and point out the "kit" cages , as someone else stated there are a few options in design , I prefer the continuos A pillar set up it takes more fitting up and time but gives (I think) the most room in the vehicle. Good luck with what ever you decide. Joe
Joe Buchanan SS/BX 3117
Old 10-15-2014, 10:36 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Joe, I do have a bender. What software are to referring to? I will consider that option.
In the "olden days" we bent a lot of custom exhaust jobs so I am not virgin with the process. We had a computer program that gave dimensions of each bend, distance and angle to next bend, etc. We used a "degree wheel" clamped into the tube and set at zero then each bent was so many inches and so may degrees. "IF" you followed the dimensions carefully the pipe fit perfectly.
Larry Woodfin 471W
Old 10-15-2014, 10:56 AM   #3
buzzinhalfdozen
Larry similar concept, as bending exhaust. I've used a few but have had good results with Bendtech, they have a few different programs from very basic to fairly complex. Look at their site I believe they even have some programs you can "try" on the site. I bought their 3D software and like it, however it does take a bit of getting used to compared to the basic systems. BTW I've messed up on more than one piece of tubing before, not the end of the world I've always found a way to use it even if it's on another project. I prefer for someone to have to "look" for the cage versus it being obvious a bit more work but worth it. Joe
Old 10-15-2014, 12:37 PM   #4
Dragsinger
after considering and pondering I ordered a 14 point set from Auto Weld Chassis. The Class Racer builds will document the install details.
Thanks to all for comments and suggestions.
Larry Woodfin 471W
