Liked 333 Times in 180 Posts
what was the last year that the Mustang LX 5.0 engine had a carb ??? or were they always injected??
Liked 7 Times in 5 Posts
1985 to the best of my knowledge.
Roland |
Liked 275 Times in 76 Posts
85 and was a stick only with the 5.0 also first year of the hydraulic roller cam.
86 was the first year of the FI 5.0 Sean
Although the 5.0 Mustang first had multiport EFI in 86, 5.0 Mustangs with automatics came with a throttle body EFI called Central Fuel Injection in 84 and 85, while the 82 thru 85 5.0 Mustangs with carbs were stick only. 82s were 2 barrel, 83-85s had a Holley/Motorcraft 4 barrel. In 1979, you could get a Mustang with a regular 302 2 barrel, with either an automatic or stick. No 302s in 80 or 81, the only V8 was an oddball 255. By the way, the 79-86 Mercury Capri was a "sister" car, and used the same powertrains, albeit with no SVO equivilent.
Thnx guys
Liked 3 Times in 2 Posts
interesting info, I have an 85 I have been wanting to do something with. I would only need to make a few changes to its current setup.
One question as I did not see it in the rule book anywhere. Do the pedals need to be stock as well? I have an aftermarket throttle pedal (mounts to the roll bar under the dash).
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
