Old 09-24-2014, 01:55 PM   #1
Slickfoot
Liked 2 Times in 2 Posts
Default Re: Update on my foxbody
Got to the 1/8 mile last night with the 5.13 gears. Got four runs in before the water pump started leaking. Best was 8.58 that was an improvement of .067 The 60ft. improved by.08, the 330 ft by.18 ... not much of an improvement.
Now that I have a bad water pump, I think I"ll change it over to a elec. set up. What are the rest of the stock foxbody racers running and what are you useing for a legal belt setup ? I still have a power steering pump.
All in all it has not been a bad year, the car has impoved by1.06 and 4.3 mph in a 1/8th all on a bone stock motor !
Lets hear about your water pump belt setup, remember legal stock.
thanks
Slickfoot
Slickfoot is offline   Reply With Quote
Old 09-24-2014, 11:26 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Update on my foxbody
Don't need power steering in a drag car,,, convert it to manual. Get an electric water pump,, there are many brands available, choose within your budget and then get an aluminum radiator with a fan,, probably puller style, then you can mount a trans cooler in front of it,, suddenly you don't need a fan belt! My 2 cents,,, good luck with your project.
Danny Durham
Old 09-25-2014, 10:59 AM   #3
rick978
rick978's Avatar
just like he said except we run an alt only . if u can afford a good elect pump do so those off shore ones s#$k
rick978 is offline   Reply With Quote
Old 09-25-2014, 12:39 PM   #4
Chris1529
Liked 70 Times in 29 Posts
I run the small moroso motor to drive factory water pump. I have a flexalite electric fan.
what RPM are you running through the 1/8 mile at?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-25-2014, 02:35 PM   #5
Danny Durham
Danny, You need to run an alternator in Stock (as of today)
Old 09-25-2014, 07:49 PM   #6
Slickfoot
I wish I could run an aluminum radiator but not in NHRA. OK in IHRA.
I do have an elec. fan, it didn't do anything for the ET, the stock belt driven one must be pretty good.
As far as finish line RPMs I didn't watch that close, it was my 1st day with the 5.13s and a tack with a shift light, but I would say 5000. Before the shiftlight I was shifting it by the stock tack and by feel. I felt like I was waiting to shift with the shiftlight set at 6000. I backed down to 5500 and no change in ET . I also short shifted in to 2nd on the 1st run by mistake with the same ET. these are the four runs before the waterpump died, 8.58 w77.72mph 8.59 w77.08mph 8.62 w77.08 8.59 w 77.47 I think it's out of motor
Slickfoot
Old 09-26-2014, 12:29 AM   #7
Geerhead55
Smile Re: Update on my foxbody
Thanks for the heads up,, Mark. I wasn't aware of that being required,,, thought it was the racer's option.
Danny Durham
Old 10-11-2014, 10:42 PM   #8
Slickfoot
Got to the track today, changes . elec. water pump, power steering delet.
(1.681 60ft) (8.38 w 79.53 mph 1/8) (13.380 w 97.55 mph 1/4 )
Slickfoot
Old 10-11-2014, 10:55 PM   #9
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Slickfoot
Nice!
Mitch Beri- The Motor City
