Old 09-22-2014, 08:39 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Problem cutting a light
Front end travel is usually a very big amount of change in RT.....
It is in a first generation F-Body....and more than a tenth is up there in those cars.
Maybe not as much in a later model with coil over type front end....
The problem is always limiting travel at some point will hurt weight transfer and traction....
Shorter front tires.....less front end travel....raise your starting line rpm as much as possible......
What do you want good RT's or the fastest ET's....One does not go with the other in a car like this......that's why people deep staged.....Speeds up RT's but kills ET's....
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2014, 11:31 PM   #2
Eman
Liked 133 Times in 76 Posts
A friend just had a VW radial come apart on him this past weekend, almost flipped car. His were pretty new, i took my old ones off and I'm glad I did
You want shorter front tires for a faster reaction time and less rollout..
I've had RT woes and biggest improvement i saw once I worked tuneup and suspension was converter. Your RT are quite a way from fine tuning something if they're in the .6's. It does sound like a stumble or delay in the engine to be that late.
My 3rd gen has a lot of frt. end travel but I can still get it to react good .
Old 09-23-2014, 08:12 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 2,019 Times in 606 Posts
What gear do you have in the rear end?
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
