Old 09-14-2014, 09:07 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Super Stock GT Truck
Don,
The GT Super 10 build is mine. Using it as an example, I will run a 1966, 327, 300 horse that is factored at 293 horse. To double check I contacted the Division four tech person about the weight and class math.
I will race in SS GT/TB - [truck B]
"B" is 10.5 pounds per factored horsepower
So, 10.5 x 293 = 3077 pounds. [rounded] next, deduct 5% for automatic trans. [3076.5 x 5% = 154, rounded] Then add 170 pounds driver weight allowance.
The race ready weight with driver is;
3077
-154 for automatic
+170 for driver
3093 pounds on scales with driver
My reasons for selection the S-10 platform;
*I have FOS [fat, old, stiff] Enter/exit the S-10 is easy. Good seating position, slightly higher than a car, comfortable seating height. Comfort in a racer is very important.
*Truck has a beefy full frame.
*Removing the bed to build new rear frame section allows much easier construction.
*I like the look and it is a newer, more modern design, body parts are plentiful and inexpensive.
*Also, I like different, I chose a step bed for that reason
Overall, I think it is a good race platform. I look forward to finishing and racing the combination. I expect to have it ready for the 2016 Division four season.
Keep an eye on the build up post as we learn more about the Super 10
PS, I think the chassis balance and "hook" will be fine. It is no more front heavy than some other combinations.
Larry Woodfin 471W
