Liked 166 Times in 46 Posts
Are you using the stock 9 1/2 inch rear brakes?
You can get an 11 inch rear brake set-up off of a Monte Carlo, or a GM mid sized car of the same body designation. I got a set off of a 77 Pontiac LeMans. |
Liked 55 Times in 28 Posts
Try some custom linings with a better coefficient of friction, rather than using standard low quality linings and more lining surface area. See my post about Ott's use of premium Abex linings. Hopefully that will help you. Also, you can't expect optimum performance before the linings are fully seated (worn in) to the drums.
#3 | |
Liked 7 Times in 6 Posts
Liked 4 Times in 3 Posts
Working on my Camaro rear brakes now---are their any Oversize wheel cylinders that are a bolt in fit (without modifying the cylinders them selves or the backing plates) OEM is 7/8" Thanks Greg
#5 | |
Maybe someone can help then. ![]() |
#7 | |
that wouldn't swap, a lot the old GM stuff swapped that was nice.. Ron that holds for you too 70 caprice shows a 1" rear that's a 1/8" jump over the Nova and front shows 1-3/16" over 1-1/8" for the Nova jumps not that big for the front may not help much. Last edited by bigfoot584; 08-26-2014 at 08:08 PM. |
