Old 08-15-2014, 05:14 PM   #7
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: ford mustang s/na question
The factory MAF is a 55MM housing, smaller and more restrictive than the 60MM throttle body housing. There is probably some performance increase there using a MAF w/ larger diameter. Not familiar with the Venom system. It looks like a MAF signal modifier that is useful for tailoring MAF transfer rates and fuel curve and probably would still work with whatever size larger MAF you go with. I run a 73MM C&L with the cal tubes to adjust for injector size. It get's the curve in the ballpark and I adjust my A/F curve with my programmer from there.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
