I'm in the home stretch in completing a 438-inch SBF for Super Street. Heads are FMS A3 castings with an Ultradyne solid roller cam. Intake is an Edelbrock/Glidden single plane Dominator intake. Converter is an ATI unit presently flashing to 5800 at the launch (behind 383 CID Cleveland). Rear gears are 5.43 turning 14 x 32 Goodyears. Launch on the brake at 3,600-4,000 RPM depending on track prep and my reaction times. Max RPM is 7,700.
I just bought a 3-circuit 1050 Dominator p/n 8896. While on line looking for baseline tune-up information, I saw many threads talking about the mods needed to lean out the intermediate circuit; converting them to two-circuit, etc. to make them run right. My question: Is this the right carb for my application, or should I box it back up and exchange it for the two-circuit version? Thanks for any guidance/recommendations you can give. |
No replies? Just looking for some feedback from you guys running 3-circuit Dominators. Good, or not worth the trouble?
Liked 1,876 Times in 577 Posts
I run one, no issues here. you should send it to Don Garbinski he works his magic on them for t-stop use.
Liked 13 Times in 3 Posts
I ran an 8896 carb for many years. As far as being lean while on stop, every combo is differant. Mine did Not like being lean. It almost seems to me that that was the hot ticket several years ago, but not seeing it as much anymore.
Chuck |
pm sent. I found his card, his website address did not come up so I sent you his #
The 8896 does not have a great calibration, not what I like to see for any app. As far as 2 or 3 circuit, it really depends on the type and setup of the stop. Most will run well with a 2 circuit, one I built for a friend running Super Street has 3 Wally's in the last 2 years and has made 2 years with it to the Jegs All-Stars.
As far as what 2 circuit works well on, if the car has an inline stop the 2 circuit will work well. If it's a plate under carb stop with only the primaries open most of the time a 2 circuit is fine. Where it gets tricky is if the primary plates get closed too far, big engine or RPM too low, or the plate is set to a 1 to 1 linkage the plates will not be opened much. In those instances getting enough air past the boosters can be an issue, and the amount of fuel delivered by the idle and transition circuits are minimal. This can run the engine on the ragged lean edge, not to hurt anything as the load on the engine at that point is low, but enough to make the car possibly surge on the stop or stumble coming off. A SMALL amount of intermediate fuel may be helpful in those instances. For a disc stop, I would suspect that because the airflow is in the center the boosters should have sufficient airflow that a 2 circuit would work just fine. |
#8 | |
I would make sure you get a stop that keeps only the primaries open on the stop. As far as more fuel at the start, there are other things you can do to help that out.
As far as what you bought, I would box it up as I don't like the calibrations in the 8896 at all. Ideally a custom 3 circuit is best, one using BLP's wide body metering blocks is what I would suggest. It's a little more initial expense for a custom carb but you will be much happier in the long run. There are several builders that use BLP parts, as well as having one built by BLP. If you are stuck on getting an out of the box model and a 3 circuit go with one of the Quick Fuel QFX 3 circuit carbs. |
Looks like their DA-6PK stop will be fine, the linkage is progressive and not 1 to 1.
