What starters are you racers running nhra stock and super stock fe powered cars using?
Lee |
X2 - I'm stuck with Auto Zone rebuilds b/c nothing else fits headers - HELP!!!
Liked 64 Times in 11 Posts
I used the Powermaster Ultratorque starter PT# 9406 250# torque on my 427 High Riser. It has adjustable clocking and shims. Works fantastic. Tom Nolan
Liked 165 Times in 54 Posts
x2
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Steve&Horace Johnson,
Well I bought a Powermaster#9406 and pulled my 20 year old Tilton Super Starter out of my Fairlane race car& installed the powermaster and now my starter relay in the back of my car just clicks when I push the toggle switch. I'm using a Painless Wiring toggle module for all my electrical functions. My tilton seemed to be ok although a friend said it could be pulling to many amps. All I did was hook my battery cable to the powermaster am I missing something? Lee |
Liked 162 Times in 45 Posts
Starter relay should be really close to the starter. Like maybe on the firewall. Proper size battery cable. Always suspect anthing that says painless. Their switches are not up to my standards.
Liked 320 Times in 102 Posts
Did you jumper the starter solenoid from the hot to the S or start terminal?????
If a remote starter solenoid is used then they must be jumpered together.. Bob
Liked 2 Times in 2 Posts
x2
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 4 Times in 3 Posts
as others have said you have to jump solenoid on starter if you need i'll try to get a picture of mine
Everett Hill 2134 STK, SS |
I guess I am confused with hooking up my powermaster as the tilton starter I removed only has the battery cable hooked to it. So what do I hook the terminal marked switch on the selinoid to? Guess a picture or drawing would help.
#4 on the instruction sheet that came with it plainly says( ATTACH BATTERY CABLE AND SWITCH WIRE. The switch wire should be capable of handling 25A. Switch wire to where? Thanks Lee |
