Old 06-16-2014, 05:16 PM   #1
SSDiv6
Default Re: Steel rod life expectancy
Originally Posted by Kevin Panzino View Post
Aluminum is a terrible material for fatigue resistance. Horrible.
A quality steel rod (not made in China) will last essentially a lifetime if kept within its design range. Not so with aluminum no matter what the alloy, or QA/QC. Its just the nature of the materials inherent poor fatigue resistance qualities.
Oliver and Manley offer very reasonably priced 100% USA material, USA forging, and USA machined rods... right around $1200 a set.
The only Manley connecting rod that is made in the USA is the Pro Beam. All the others are off shore blanks machined in the USA.
Old 06-16-2014, 11:07 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
That would be news to me and would result in an extremely irate phone call to both manley and patterson racing tomorrow morning....
Are you saying the Manley TourLite series which they specifically tout as 100% USA made, are in fact offshore forgings?
Old 06-17-2014, 01:54 AM   #3
SSDiv6
Kevin, the only connecting rod I know is 100% USA is the Pro Beam Billet.
Manley exports crankshafts, piston pins, retainers and connecting rods from China.
Their Titanium valves from Israel and the other valves from India.
Just take a look at the following Bill of Lading as examples:
http://portexaminer.com/trade-data/s...tshanycd10470/
http://portexaminer.com/trade-data/r...chydnyk000163/
http://portexaminer.com/trade-data/s...iawofy1311035/
http://portexaminer.com/trade-data/s...lae3116141nyc/
Old 06-17-2014, 06:55 AM   #4
joespanova
Liked 13 Times in 11 Posts
In a situation like mine , where you lose an aluminum rod..........was it a bearing / oiling failure that caused the rod to fail...........or the rod getting kicked out of shape that made it "appear" to be a bearing failure? Hard to say.........the crank has bearing metal transfer that was obviously hot...........but why? Which came first ? Is the oil system adequate ?
Rods probably have 120ish runs on them.
Old 06-17-2014, 07:08 AM   #5
SSDiv6
With that many runs, material fatigue.
Old 06-18-2014, 09:50 AM   #6
Dion Hildebrandt
Dion Hildebrandt's Avatar
Cut open the oil filter, it will give a better picture on what happened first. Had the same thing happen recently, and the filter was loaded with brass indicating a bearing failure.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 06-18-2014, 10:17 AM   #7
joespanova
Good point. In aluminum rod combos where the rod has plenty of cycles you would tend to think its a rod failure , BUT , a bearing failure is certainly a possibility......... with the rod getting kicked / stretched out of shape that in itself may have caused the bearing failure.......chicken or egg?
Old 06-18-2014, 10:32 AM   #8
Ed Wright
Ed Wright's Avatar
Every aluminum rod failure I had pulled into in the middle. Big eng spun freely on the crank, with a good bearing inside. All big end failures I have seen were bearing failures. If it's black, it sure wasn't the rod.
When you set your bearing clearances, think about the expansion rates.
Ed Wright 4156 SS/JA
Old 06-17-2014, 01:53 PM   #9
Mike Schwartz
Liked 252 Times in 91 Posts
That's an interesting site. I used it to check who is importing nitromethane. (http://portexaminer.com/search.php?s...t=nitromethane) Schumacher Electric & VP Racing Fuels are there, but also a lot of names I don't recognize.
Old 06-17-2014, 02:25 PM   #10
SSDiv6
Yep. If you do a search, you would probably remember many years ago the war between Schumacher, NHRA and VP Fuels. As I remember, Schumacher was buying Nitromethane from China and selling it to other racers at a lower price than VP and probably also hurting the profits.
