#1 | |
Liked 1,579 Times in 582 Posts
FIREWALL Firewall may be recontoured for distributor or magneto clearance only, and must be properly refinished. The lower portion of the OEM firewall may be replaced with steel of equal or greater thickness than OEM. Chevy Cavaliers, Pontiac Grand Ams and Sunfires, and Ford Escorts may have firewall replaced or relocated, provided the measurement from the rear of the radiator core support to the firewall is 34 inches maximum. For Chevy Cobalt the radiator core support to the firewall is 33 inches maximum. For all others vehicles, firewall must be in the original location. A complete onepiece steel firewall that resembles OEM must be installed, welded in place, and sealed from the driver compartment. The firewall must extend to and attach to the floor. The firewall and mid-plate must be two separate pieces. All motor plates, mid-plates, etc. must be separate from and may not be attached to the firewall. Additional alterations prohibited. Engine must not touch firewall. Firewall coverings prohibited. See General Regulations 7:4. FLOOR Stock mandatory. Floor-mounted clutch/brake pedals permitted. Headers must fit under stock floor location. The stock framerails from the firewall to the radiator support must retain stock attachment configuration, stock location, and stock dimensions. Frame may be notched for header clearance. |
Liked 237 Times in 126 Posts
There is an OEM floor pan under the fabricated floorboard. It's Modified Stock. Still don't know if you can do all that to a car.
http://www.brinkracecraft.com/Galler...1/P2189248.htm Dale
Liked 28 Times in 1 Post
Did not build car for GT, modified and super modified, OEM floor is in place as per rules, we put the bars above the floor, which isn't appealing, so then fab a "sub floor" for aesthetics only, I left the area under the seats open so anyone can see the original floor, the firewall can be replaced and relocated to 34" from radiator support, for escorts and cavaliers, diff for cobalts, it does not have to resemble stock, as a fwd firewall has way too many holes in its stock form and would look terrible, it does have to be steel, the mid plate has to be separate and not part of firewall, I am a long time modified guy, it is very tricky to build a FWD conversion, I did not understand why all the allowances were made either until I built one, you are making a RWD where nothing was before
Ashton Hudson SS/CS 4373 |
#4 | |
Dale
