Old 05-12-2014, 07:56 PM   #1
Liked 5,121 Times in 1,952 Posts
Default Re: 1976 nova drive shaft length
Originally Posted by MikeMoller View Post
Can anyone give me the correct ujoint to ujoint driveshaft length for a 1976 Nova with an 8.5 10 bolt rear and a stock metric 200 trans. Car had a 7.5 10 bolt and I need to modify the drive shaft.
Thanks
Mike, In theory, you could shorten the original shaft 1",, but I still wouldn't do it that way.
Do you have the original shaft?
You could very likely find what you need at the "Pick a Part" once you measure it up.
Old 05-12-2014, 08:07 PM   #2
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Mark,
I have the original shaft but believe it to be to long. I have found a few in the local yards while hunting other parts, but most were way to rusty and my original is in good shape. There is a good local shop that will shorten and balance for $50. Should have the new rear finished this week, so I will install it and measure per the suggestions. I found a post in a Nova web site says it should be 51 1/2. We'll see.
Thanks for all the suggestions guys.
Mike Moller
NHRA 203 Q-R-T/SA
