Old 03-08-2014, 10:40 PM   #1
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: EFI, Alpha-N vs Speed Density fueling Strategies
I can see how using a Speed Density map would get the last bit of performance on a heads up run, or in a no-breakout index class such as Comp.
But, if the afr is changing while going down track, doesn't that make it harder to predict an accurate dial in? Whether using a weather station formula, or one's own ratio of performance loss or gain per 100 feet altitude change, don't these calculations assume the afr is not being adjusted from run to run, let alone during the run?
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
