Old 03-08-2014, 12:13 AM   #31
Tom Moock
Liked 10 Times in 6 Posts
Default Re: Dyno numbers 305
philbilly, good luck at sgmp, be careful doing your burnout when come out of the water, don't over rev your motor or you will bend your valves, it's easy to bend them, I'd try 6200 shift point, if you stay in low gear to long you will fill the car slow down. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
